Old 07-28-2008, 10:14 PM   #51 (permalink)
southwest2118's Avatar
southwest2118 is on a distinguished road
2023 kbit/sec
0.101s latency
4.136s d/l time.
too bad its my home computer with cable....wait...thats sad
and q9h from the DFW with opera
Speed: 292kbit/sec
3.966s latency
28.575s d/l time
somethings not right ...if i do it back to back i get different results ..
in IE
Speed: 622kbit/sec
0.395s latency
13.564s d/l time
but the first time was like 192kbits per second ?
soo my final conclsion is that these tests are not accurate.
southwest2118 is offline
Old 07-28-2008, 10:50 PM   #52 (permalink)
RJNJC's Avatar
RJNJC is on a distinguished road
Need Help
Which is why it is always a good idea to get a set of results (minimum 3) within a same set of parameters and get a trend.
Speedtests vary on a lot of factors: time of day, distance from server, location etc etc...and should be used only to get an idea or indication and not be treated as gospel.
RJNJC is offline
Old 07-28-2008, 11:04 PM   #53 (permalink)
amen to that
The Following User Says Thank You to southwest2118 For This Useful Post:
tmed834 (08-07-2008)
Old 07-29-2008, 01:11 AM   #54 (permalink)
mexiken's Avatar
Originally Posted by kareljack View Post
If you recall in th eother thread that 3g speeds was discussed, I am only getting about 300-400k down. So streaming video is not a very satisfactory experience for me.
If my issue resolves itself and I am back to 600-700k then there will be some semblance of satisfaction, but like ninjaap said we are paying a premium here.
You know what, you're right. For some reason, I thought you were getting the same speeds as me.
Yeah, thats a bit of a drag. You should call and ask why the slow speeds. Can't hurt. Tell them you have friends that get much faster speeds with this phone. What could it hurt ????
mexiken is offline
Old 07-29-2008, 10:46 AM   #55 (permalink)
hello is on a distinguished road
Enable band selection:
1. Go to Home Screen
2. Type *#1546792*# and then send
3. You will see new screen that indicates that Band
Selection was enabled
4. Now you can go to Settings/Phone/Network/Band
Selection
when i did it, i saw: "Signalling Error" and nothing happened
maybe because i don't have any 3G connections ?
hello is offline
Old 07-29-2008, 03:48 PM   #56 (permalink)
mexiken's Avatar
Try this:
Go into your Windows directory, look for bandselect.exe, and make a shortcut to your start menu. Thats the app with the UI interface itself. Enjoy.
mexiken is offline
The Following User Says Thank You to mexiken For This Useful Post:
hello (07-30-2008)
Old 07-30-2008, 01:36 AM   #57 (permalink)
Originally Posted by mexiken View Post
Try this:
yes it works!!!
default value is "automatic", i choose: GSM
hello is offline
Old 07-30-2008, 01:38 AM   #58 (permalink)
mexiken's Avatar
yes it works!!!
Good deal. Glad it worked. And thanks for the thanks
mexiken is offline
Old 08-01-2008, 10:59 PM   #59 (permalink)
No Remorse is on a distinguished road
after 6.1 update saw an average of 600 to 800 kbits/sec. latency down to .500 to 1.5 sec. might just be me but if you havent done it give it a shot !
No Remorse is offline
Old 08-10-2008, 01:47 AM   #60 (permalink)
mr2spyderfreak13 is on a distinguished road
Default wm 6.1 por favor
Originally Posted by ninjaap View Post
so...it's obvious that d/l time stands for download time, but what do the other two values stand for? I got the following values:
IE:
490kbit/sec, 0.623s latency, 17.075s d/l time
Opera:
457kbit/sec, 0.528s latency, 18.415s d/l time
heyy my dud ei realized you got WM 6.1 on your Q9h. where did you get it??can i ge tthe link????
mr2spyderfreak13 is offline
