Old 07-17-2008, 04:32 PM   #1 (permalink)
warriorpluto is on a distinguished road
Default no antenna nor bluetooth
i cant get my phone antenna to start up nor work. its not even an option in wireless manager. bluetooth wont start neither. says cant load bluetooth stack.
also i tried the master reset by pressing e and z on startup and still the same thing. also i went into phone information and under radio, bp, bp flex, and dsp it says unavailable. ????!!!!
warriorpluto is offline
Old 07-17-2008, 04:55 PM   #2 (permalink)
mexiken's Avatar
Oh wow. Did you try a hard reset ???? Take the battery out with the phone still on.
If that doesn't work, you might be looking at a defective unit.
mexiken is offline
Old 07-17-2008, 05:36 PM   #3 (permalink)
yep tried that already. i was thinking about flashing it. i have the files. but my data cable went dead.
Old 07-17-2008, 05:46 PM   #4 (permalink)
and is the radio located on the micro sd card slot motherboard with the camera flash? if thats the problem i could probably get a replacement. or find one. but im going to wait until my other data cable comes in and try to flash it.
Old 07-17-2008, 08:35 PM   #5 (permalink)
mexiken's Avatar
Yeah def try a flash.
The 6.0 files are over on mmuk if you need them.
mexiken is offline
