Originally Posted by madmartian Anyone know how to connect a WIRED headset to the Q9h? It appears the adapter that comes with it is for stereo headphones (no mic), not a headset (with mic).
1. Is there a headset adapter?
2. Is there a mini USB headset that worked with the regular Q? I might be able to use that via a mini-to-micro USB adapter.
3. Is there a wiring diagram for the microUSB port that shows what pins to attach mic and speaker to? |
Oops about the thanks, can't multi-task - oh, well, 'tis the season for giving...
Anyway, yes, the RAZR series (eg V3i) has a mini-USB headset which works fine with the micro-mini adaptor.... it's a bit ugly, but it works.
If I recall, the EURO version came with the proper headset which has the "bend" to make the wire flush with device.
