Old 06-09-2008, 10:23 PM   #51 (permalink)
ptlee8202 is on a distinguished road
Originally Posted by annsera View Post
Just goes to show that you never know what posts will be helpful, sometimes the mistakes are the most helpful. I was stopping the kickstart app too quickly (around 4 mins). If it wasn't for CBonney's post that said 6 minutes, I wouldn't have let it go long enough. It really did take that long. Now, google maps is up and running, although, I've run it only once, so I'm keeping my finger's crossed that it will stay that way!
Now, am I going to have to run the kick-start every time I run google maps and wait this long? I certainly hope not. We'll see. I hope this was a one time thing...
Lately, I have been using the AT&T Maps app to 'kickstart' the gps. I have been getting good results too. Especially with WLS. I just loaded the app. I did not upgrade to navigator nor am I using the actual service.
Arrogant A$$
ptlee8202 is online now
Old 06-09-2008, 10:59 PM   #52 (permalink)
mworsham is on a distinguished road
Send a message via Yahoo to mworsham Send a message via Skype™ to mworsham
Which app is that exactly ptlee?
Mark W
mworsham is offline
Old 06-09-2008, 11:23 PM   #53 (permalink)
its the one thats on the at&t q9h global. it says at&t map when you install it. and it has an upgrade to at&t navigator.
The Following User Says Thank You to ptlee8202 For This Useful Post:
mworsham (06-10-2008)
Old 06-09-2008, 11:24 PM   #54 (permalink)
mexiken's Avatar
Mark W
I believe hes referring to Telenav. Its been renamed AT&T Navigator now.
Thats kinda smart. I'm gonna try that. Right now actually.
mexiken is offline
Old 06-10-2008, 09:41 AM   #55 (permalink)
Cool. Let us know how it goes. I have no problems with the GPS, I use it with Live Search all of the time. It just takes a long time to start up, and I kick-start it with GPS Test.
Mark W
mworsham is offline
Old 06-10-2008, 02:47 PM   #56 (permalink)
mexiken's Avatar
Bummer.
I deleted the "Get Telenav" icon when I was moving icons around on my start menu. I tried navigating in Media Mall to it, but no dice.
I'll try with my comp right now.
mexiken is offline
Old 06-10-2008, 07:26 PM   #57 (permalink)
noSup4u is on a distinguished road
I've been having some serious issues getting GPS to work. GPSID fails to update any settings. I've attempted to edit the registry to allow editing but nothing seems to allow it to do the simple updates to enable my GPS.
It says one of the two things:
Failed to update GPS driver.... or
Unexpected error in settings.exe
Has anyone experienced this? I've tried reinstalling the cab file a few times.
noSup4u is offline
Old 06-11-2008, 11:01 AM   #58 (permalink)
It still has Telenav in some small print but the "about" shows that it is AT&T Maps Version: 1.2.0.7 with an option to upgrade to AT&T Navigator.
Turn on the gps status icon with the registry setting:
HKLM\Services\LCAService, DisplayIcon=1
You will see that as soon as you load the ATT Maps program it is starting to aquire a lock on gps satellites. You don't need to do anything else in that program. But, if AT&T has any inside info to use the gps to get the fix faster then you will get the benefits.
Arrogant A$$
Old 06-11-2008, 11:08 AM   #59 (permalink)
annsera is on a distinguished road
Default I'll try ATT telnav
with the GPS Test kickstart, I'm still taking 6 mins or so to acquire a lock. Thus, I either have to leave GPS running constantly, or wait 6 mins every time I want to use GPS. This seems nuits. Now, I'm abouit 7 miles outside of Boston. It's not ridiculously hilly here, nor am I out in the wild, and we're not even particularly dense either (signal can't realistically be obscured by buildings or other signals, I think). I can't figure out what is going on.
I'll try the ATT kickstart to see if it's any faster. Hope so!
annsera is offline
Old 06-11-2008, 11:27 AM   #60 (permalink)
Bummer.
I think you can use Opera and go to "http://ota.telenav.com/ota/at" to get the cab. For some reason, if you use IE the site does not recognize your device.
Arrogant A$$
