Originally Posted by ilkevinli I need to run Jbed for a program that allows me to see live video feed from my security cameras at my house. The problem is the bottom 1/4 of the screen is cut off when its loaded. Does anyone know how to correct this ? Does anyone else see the same issue ? Thanks. |
you can try to use a tool which called javamagic to modify the .jar file yourself to specify the reslotion to 320x240.
