Old 05-05-2008, 10:03 AM   #1 (permalink)
bxloco12 is on a distinguished road
Exclamation Help!!!!!
Does anyone know the hack to increase the volume when i listen to music through my headset on the Moto Q global ive tried the hacks that were posted here before but they dont work can someone plz help me
bxloco12 is offline
Old 05-05-2008, 10:05 AM   #2 (permalink)
hold in scroll wheel and scroll up
Old 05-05-2008, 10:06 AM   #3 (permalink)
tried that already and nothin
bxloco12 is offline
Old 05-05-2008, 12:20 PM   #4 (permalink)
mike250rs's Avatar
press up on d-pad. Also there is a volume hack in the hack sticky
mike250rs is offline
Old 05-05-2008, 05:26 PM   #5 (permalink)
i tried both those things the hack only makes it to the basegains folder but when i open it there are no subfolders
bxloco12 is offline
Old 05-05-2008, 05:38 PM   #6 (permalink)
mike250rs's Avatar
yep, you change the basegain values. Most are set to 8 by default 12 will rupture your eardrum.
if your usimg PHM navigvate to the folder and select values (left soft key)
Old 05-07-2008, 07:29 AM   #7 (permalink)
im usuing resco could that b the problem
bxloco12 is offline
Old 05-07-2008, 08:40 AM   #8 (permalink)
mike250rs's Avatar
I can see it with resco, once you navigate to the folder all the keys show up. Unless there is something different witht the Q9's
Old 05-07-2008, 08:45 AM   #9 (permalink)
PacoJr67's Avatar
once you're there you need to get your editor to show the values (in PHM you press the left soft key)
PacoJr67 is online now
Old 05-07-2008, 02:41 PM   #10 (permalink)
Oldergeek is on a distinguished road
Default Also interested in this hack
I've been following this thread with interst also. I think that there must be an issue between Q models. I have the Q9h and there are no values that show up when I press the left soft key at this point. On other registry items this has always worked, but on this particular item, the opitions (values) aren't there for me. I'm using PHM registry editor.
Oldergeek is offline
