Old 05-15-2008, 10:52 AM   #11 (permalink)
tendomentis is on a distinguished road
Originally Posted by TreeFrog View Post
install it..run it..un-install it!
Yeah, 'cause THAT philosophy won't kill your registry over time...
tendomentis is offline
Old 05-15-2008, 02:12 PM   #12 (permalink)
ninjaap's Avatar
Yah... un-installing programs tend to leave components behind.
ninjaap is offline
Old 05-15-2008, 02:46 PM   #13 (permalink)
TreeFrog's Avatar
I use SKTools....the better picker-upper! It cleans up the registry too. And if it doesn't I ain't scared to do it myself!!!
TreeFrog is offline
Old 05-15-2008, 05:33 PM   #14 (permalink)
ninjaap's Avatar
I use that too. Excellent app. Unlike you, im too lazy to clean it up myself. hehe.
ninjaap is offline
Old 05-15-2008, 10:14 PM   #15 (permalink)
mexiken's Avatar
I guess so. But you could also change the settings around in outlook on the comp then sync it. That makes it easier. I just hate installing apps when i don't need to.
You can change what it defaults to ???? How is this ????
mexiken is offline
Old 05-16-2008, 12:29 PM   #16 (permalink)
Hi ;)
In Outlook, under Tools>Options> Preferences tab (or might be another tab depending which version you run) there is a Contacts Options, go in there and it should give you the option for "File As" and you can default it to show First Name Last Name or vice versa.
~maria
LuvrGirl is offline
Old 05-16-2008, 01:40 PM   #17 (permalink)
mexiken's Avatar
Originally Posted by LuvrGirl View Post
Hi ;)
~maria
Nice. I knew that....er....
Still doesn't solve the little problem that sometimes when you make a change on the phone, it will change the "File As" name to their first and last. Last, then first.
mexiken is offline
