Old 12-19-2007, 10:43 AM   #1 (permalink)
drew93 is on a distinguished road
Default Cingular Q ringtone problems
i am having problems putting ringtones on my cingular motorola q 9h. i have put them in the sounds folder and they show up there but when i click into sounds on my phone they arent there. i can also play them in wmp but for some reason they will not show up in the sounds folder to add them as a ringtone. if anyone knows why could you please help me out thanks!
drew93 is offline
Old 12-19-2007, 10:49 AM   #2 (permalink)
drew8484 is on a distinguished road
To use as a ringtone for your phone they need to be in the ringtone folder. To use as an alert sound, ie; text, email, etc they need to go into the sound folder.
drew8484 is offline
Old 12-19-2007, 11:02 AM   #3 (permalink)
they are in the ringtone folder also and still do not show up on my phone
drew93 is offline
Old 12-19-2007, 11:02 AM   #4 (permalink)
welcome both drew's...
drew93 is this something new for the Q9 ? on the Q1 all sounds go in the same directory.
Old 12-19-2007, 11:06 AM   #5 (permalink)
its for the cingular 9h. i read that you have to delete the file size limitation or something. i am trying to do so but cannot figure out how to work this registry editor. can someone tell me how i would go about running the registry editor? thanks
drew93 is offline
Old 12-19-2007, 11:08 AM   #6 (permalink)
The Q9h has two seperate folders. I had problems using my ringtones as alert sounds until I realized that. I have 147 ringtones that I installed. They are WAV, WMA, and MP3 formats. The only one that doesn't show up is a WAV file 438kb. All the rest of the files are under 200kb. I did see a post on how to change the size limitation if that is your problem.
drew8484 is offline
Old 12-19-2007, 11:11 AM   #7 (permalink)
Also, I made all my ringtones on a free site, phonezoo.com. In doing so I do not have to change the registry, as they were all under 200kb.
drew8484 is offline
Old 12-19-2007, 11:16 AM   #8 (permalink)
did you see this thread ?
Old 12-19-2007, 11:34 AM   #9 (permalink)
yes but i do not even know how to use a registry editor.
drew93 is offline
Old 12-19-2007, 11:37 AM   #10 (permalink)
do you already have one installed on the Q ? or on the pc that can edit the registry on the Q.
