Old 12-27-2007, 07:46 PM   #11 (permalink)
PatientShadow is on a distinguished road
Default OK
i will try this when i get home, thanks
PatientShadow is offline
Old 12-27-2007, 08:07 PM   #12 (permalink)
mike250rs's Avatar
*assuming record with audio is checked in camera settings*
if it can't even play audio with vids created on the phone ...I would call it toast
mike250rs is online now
Old 12-27-2007, 08:42 PM   #13 (permalink)
MBK2's Avatar
MBK2 is on a distinguished road
It may just be a WMP setting problem, or perhaps WMP codecs somehow got corrupted, not the first time Microsoft apps went haywire. Trying TCPMP can see if it related to WMP or the Q itself, no?
MBK2 is offline
Old 12-27-2007, 09:22 PM   #14 (permalink)
mike250rs's Avatar
shouldn't the WMP settings have been corrected after OP did a master reset?
Old 12-27-2007, 10:14 PM   #15 (permalink)
MBK2's Avatar
You would think so, but you would also figure that the music wouldn't play either if it was the Q itself, but he states that music plays. So testing another media player is a simple alternative to test any possibility that needs to be eliminated to narrow down the cause of his issue.
MBK2 is offline
Old 12-28-2007, 01:01 AM   #16 (permalink)
mike250rs's Avatar
odd.... guess we shall see what fun TCPMP will bring.
wonder if OP's "feedback" will also include the entire tech support and possible swap process the average Joe would endure :-)
Old 12-28-2007, 01:44 AM   #17 (permalink)
ok TCPMP works, and the sound works for videos i recorded with my phone. but videos played through cellular video still has no sound. and it is still run through windows media player
Old 12-28-2007, 04:41 AM   #18 (permalink)
MBK2's Avatar
OK, at least we established that your Q is able to play videos with sound.
TCPMP does not have the audio codec to play the 3GP video recorded with your Q. Those video clips need to be played with WMP, so I'm leaning torwards what mike referenced earlier about making sure you are recording the video 'with' sound using your Q's video recorder.
MBK2 is offline
Old 12-28-2007, 05:22 AM   #19 (permalink)
mike250rs's Avatar
playing a supported file in both players should confirm if WMP is faulty or not
Old 12-28-2007, 02:27 PM   #20 (permalink)
Informative ok... so some files that will play
with TCPMP, and audio works.... the same files will play in WMP, but audio does not work. Anyone know if there is a way to uninstall WMP, and reinstall it? Or would i just have to attempt to get another device? I love this Q9 way more than my old 8525, or the Tilt...
