Old 09-28-2008, 05:11 PM   #21 (permalink)
kambrose is on a distinguished road
Default won't work
Originally Posted by mexiken View Post
Ok, heres what I have:
HKCU/ControlPanel/Sounds/ShutterSound
Under sound, change it to "\windows\*none*
Thats what I have, and there is no sound.
It will disable camera!!!!!!!!!!!!!!!!!!!!!!wont work wont work
won't work, won't work(still engineering fix)
Last edited by kambrose; 09-28-2008 at 05:14 PM. Reason: want to make info well known before someone else
kambrose is offline
Old 09-29-2008, 04:04 PM   #22 (permalink)
eahagan is on a distinguished road
Default get rid of the shutter sound
I think someone already said this but to confirm...
HKLM/System/Pictures/Camera/OEM/PictureLocation
There are 3 options here
ForceShutterSound
ShutterSoundVolume
SoundFile
Change the volume to 0 and that should get rid of it
You can also delete the text under the sound file
both ways worked for me
If you get rid of the sound file here it will also be gone when you go to
HKCU/ControlPanel/Sounds/ShutterSound...
eahagan is offline
Old 09-30-2008, 11:17 AM   #23 (permalink)
Default Won't work
Originally Posted by eahagan View Post
i think someone already said this but to confirm...
Hklm/system/pictures/camera/oem/picturelocation
there are 3 options here
forceshuttersound
shuttersoundvolume
soundfile
change the volume to 0 and that should get rid of it
you can also delete the text under the sound file
if you get rid of the sound file here it will also be gone when you go to
hkcu/controlpanel/sounds/shuttersound...
when u apply those changes the sound is gone, but when u restart the phone the camera is disabled as per policy! You can easily get the camera to work again without the sound, but, the anoying popup will keep coming back.
kambrose is offline
Old 09-30-2008, 11:19 AM   #24 (permalink)
Default Wont work
You can change the registry settings, and the shutter sound will be gone, but when you restart the phone you get a message that the camera has been disabled as per policy.
kambrose is offline
Old 09-30-2008, 11:21 AM   #25 (permalink)
Default Moto q9 global mobile 6.1
Don't know if this reg. Hack is for mobile 6.0.....please specify os.
kambrose is offline
Old 09-30-2008, 12:11 PM   #26 (permalink)
Default ATT Moto Q9h Global WM 6.1
My phone: ATT Moto Q9h Global WM 6.1
I made the exact changes on my phone that I posted earlier and didnt get anything close to what you are saying is happening to you.
I was looking back through the registry path and I think I might have an idea, though I am not sure about it... just a thought.
Make sure you follow this exact path:
You will see these values:
forceshuttersound
shuttersoundvolume
soundfile
if you happened to go to:
HKLM/System/Pictures/Camera/OEM/DisablingConditions
(instead of PictureLocation) you will see the same values that are in the PictureLocation folder.
I didnt try to make any changes here but just a guess that since this is labeled DisablingConditions if you change something here you might wind up "disabling"
I'm going to mess around with it a little bit and see if I can figure anything out for sure.
Also:
Can anyone tell me what the original volume was for the shutter sound?
eahagan is offline
Old 09-30-2008, 12:48 PM   #27 (permalink)
well never mind that so much. they both change simultaneously
after changing the volume in picturelocation i dont get anything about disabling even after restarting multiple times and using the camera.
weird. do u have the same version - wm6.1?
[quote=eahagan;245801]My phone: ATT Moto Q9h Global WM 6.1
forceshuttersound
shuttersoundvolume
soundfile
eahagan is offline
Old 09-30-2008, 12:58 PM   #28 (permalink)
Default Is it this message?
Is it this message?
"Remote management policy prohibits the use of the camera feature."
eahagan is offline
Old 09-30-2008, 01:01 PM   #29 (permalink)
Default ok...
if that is what you are getting, what do you have for the values under DisablingConditions/0809 for CSPValue and NeedUpdate
I had 0 on both and changed to 1 and when I tried to use the camera I got the message that I think you are getting
eahagan is offline
Old 10-04-2008, 08:17 PM   #30 (permalink)
Default camera shutter
Originally Posted by ChantryChantry View Post
i know it's for safety reasons and all, but i'd like to get rid of the shutter sound that plays when i take a photo. all the registry hacks i've tried dont work. if someone has a working one, that'd be be great.
Just set shuttervolume to 200. worked and didn't get error message phone disabled. done seeya have a nice day.........
kambrose is offline
