Old 03-27-2008, 04:39 PM   #1 (permalink)
lbmmoh is on a distinguished road
Default 1 Speed Dial does not dial Voicemail anymore
Had anyone lost all their speeddial functions before? I used to have each digital assigned to speeddial, and my #1 is reserved for VM, but it does not work anymore. VM is not in my contacts either, anyone know why this happened and how to fix it? Thanks
lbmmoh is offline
Old 03-28-2008, 05:28 AM   #2 (permalink)
Desiree Q's Avatar
Desiree Q is on a distinguished road
Send a message via Yahoo to Desiree Q
Lightbulb
I can't tell you how this might have happened but I might be able to help you with a fix...
Start>System Tools>Settings>Phone>more>My numbers
Make sure your phone number with the 1 in front (1xxxxxxxxx) is in voice line 1. If not, menu>edit.
Go to Start>Speed Dial and check to see if voice mail is listed in the first position. If not, there is a help section there to tell you how to add a number.
Hope this helps,
DQ
Desiree Q is offline
Old 03-29-2008, 11:35 AM   #3 (permalink)
ajfcpajd is on a distinguished road
I've got the same problem. When I try to save it the phone tells me that space #1 is reserved.
ajfcpajd is offline
Old 03-29-2008, 03:26 PM   #4 (permalink)
Desiree Q's Avatar
There are a couple of threads that might be helpful depending on your phone and carrier. Here are a couple:
Speed Dial Link
Voice Mail Link
DQ
“The footprints you leave behind will influence others. There is no person who at some time, somewhere, somehow, does not lead another.”
Old 03-30-2008, 04:09 PM   #5 (permalink)
The settings are right, but for some reason holding down 1 still does not work. Ive just reassigned my own number to a different keypad number and holding down that works. Id rather have it working like it used to though.
lbmmoh is offline
Old 03-30-2008, 05:35 PM   #6 (permalink)
Icer Mize's Avatar
Icer Mize is on a distinguished road
I cannot comment as to why you may have lost all speed dial functions but I have had an ongoing problem with Outlook. It does not store either the speed dial or custom ring tones assigned to my contacts. I frequently get sync. error messages regarding a change in my server (which there wasn't) and when I try to correct it the phone loses the speed dial and custom ring settings.
If someone knows where the contact data is stored on the phone I might be able to write a routine that will back it up.
Good luck!
Icer
Icer Mize is offline
Old 03-30-2008, 10:38 PM   #7 (permalink)
Desiree Q's Avatar
Exclamation
Which Q do you have? Did you look at the DTMF and My Number Settings (I'm sure you did). It doesn't make sense that the other numbers work and #1 doesn't. *scratching head*
We need the SUPER MODS on this one! Hockey? Rude Boy? Somebody help us noobies! We're drowwwwwwniiiiiiiing! LOL LOL
DQ
Old 03-31-2008, 08:44 AM   #8 (permalink)
Yup, I have a Q9h global. no idea why just "1" is dead
lbmmoh is offline
Old 03-31-2008, 08:58 AM   #9 (permalink)
Desiree Q's Avatar
When you go into settings>phone>call options, do you see your phone number and voice mail number to your carrier?
Old 03-31-2008, 09:20 AM   #10 (permalink)
My options do show my phone number and voice mail number. The 1 just doens't work. I thought it was just mine, but this seems to be a somewhat common problem.
ajfcpajd is offline
