Originally Posted by yueyang It is quit annoying. Every time when Q9c freezes up, I have to remove battery to reset it. Then the battery icon will be changed to unrecognizable status (with a cross on it). Although keeping charging it overnight will make the battery recognizable again. I just got the phone one month ago, it shouldn't be the battery's problem. It there any hard keys to reset Q9c when it freezes up? Removing battery everytime is quite stupid. Any suggestion? thanks ! |
You can try pushing and holding the red power button to turn your Q off, but if the freezeup is bad enough, that won't work. Unfortunately, the battery pull may be your only option.
