1. how do you type an underscore on this phone? ( _ )
2. why cant i hit question mark sometimes? it just shows up 0 no matter what. i hit function....etc... stilll just shows up 0.
To type the Underscore hit the Fn button then the Caps button and that will bring up many different symbols and such. The underscore is the first one I believe.
Uninstalling Candle Light will not fix the problem. A master reset is needed to fix the ? key.
Avoid candle light at all costs. I'm basically an expert on the candle light.
