Old 03-23-2008, 05:29 PM   #1 (permalink)
lm50538 is on a distinguished road
Default help with apps not working
hi, new to the 9c and have a few questions if anyone can please help me i'd appreciate it very much :D
i was trying to optimize space when my q9c prompted me to move/delete files since i was low on space. somehow i moved the instant messaging files and now i can't open the app. i also did the same with the telenav app. how can i get them back?
also i what are some tips/tricks to maximize space? how do i unistall a program i installed? i know i saw an unistall folder and now i can't find it.
again tia :D
lm50538 is offline
Old 03-23-2008, 05:41 PM   #2 (permalink)
PacoJr67's Avatar
You can remove programs by going to start > settings > remove programs (should be on the second page)
Some tips for file management:
Don't let you text messages and emails accumulate. while it can hold quite a bit, many people overlook the sent messages. Also get a copy of SK tools, it helps to keep your phone tidy by cleaning up bad shortcuts and the registry and such.
PacoJr67 is offline
The Following User Says Thank You to PacoJr67 For This Useful Post:
lm50538 (03-23-2008)
Old 03-23-2008, 05:50 PM   #3 (permalink)
thanks so much, what is sk tools?
lm50538 is offline
Old 03-23-2008, 06:00 PM   #4 (permalink)
rainmakerrc's Avatar
It's a program to free up memory on your Q. The lite version is free and will help to keep your Q's memory clean and free of junk. I have a copy of the .cab file for the lite version on my apps page if you want to try it out.
Rob
Apps on my Q9c
rainmakerrc is offline
Old 03-23-2008, 06:19 PM   #5 (permalink)
thanks so much, checking out some of the other apps u have on there too
lm50538 is offline
Old 03-23-2008, 08:42 PM   #6 (permalink)
always use start settings remove programs to get rid of apps
to free up space clear you internet history
open up IE and hit the right soft key..then hit options and finally memory and clear each of the items
Old 03-23-2008, 11:07 PM   #7 (permalink)
thanks so much! that deleted 15 mb of crap!
lm50538 is offline
Old 03-24-2008, 11:55 AM   #8 (permalink)
good deal
thats what it usually is
