Old 10-02-2008, 09:42 PM   #1 (permalink)
Avenger626 is on a distinguished road
Default Help! Took apart my Q9c and cant figure out how to reconnect the lcd screen
Title about sums it up. I just need to know if anyone knows what is required to be connected internally for the lcd to work properly. I know there is a white peice on the ribbon off of the lcd...that is hooked up good, the rest sorta just sits in place under the SD PCB.
I had a cracked cover/plate and bought a new plate...i bought the verizon one cause i like that look better. anyway, the lcd screen worked while the phone was all busted up looking...now with the new cover it lights up white. Everything else works, calls come in, go out, speakers work, everything but the picture.
http://i14.photobucket.com/albums/a3...reenonQ007.jpg
http://i14.photobucket.com/albums/a3...6/DSCN1788.jpg
On this next picture... you can see the ribbon that goes from the lcd to the main board. I put an arrow where the white peices connect. I have those hooked up good, even pushed down on the top of the ribbon to make sure it was snug onto the board and plugged in at that point.
http://i14.photobucket.com/albums/a3...626/zoomed.jpg
However to the left of the white peice on the ribbon there is other parts that I dont know if need to bond to something else or what.
http://i14.photobucket.com/albums/a3...6/sideshot.jpg
Avenger626 is offline
Old 10-06-2008, 12:40 AM   #2 (permalink)
anybody know if the rest of the ribbon is supposed to bond?
