Old 08-19-2008, 07:08 PM   #1 (permalink)
j_hoff_05's Avatar
j_hoff_05 is on a distinguished road
Default Help!
my vol is set up on outdoors, every other sound is loud except the incoming call vol
its very very quite
anyclues?
USC MOTOq 9C LIME
j_hoff_05 is offline
Old 08-19-2008, 07:11 PM   #2 (permalink)
PacoJr67's Avatar
press and hold the thumb wheel and adjust the volume from there.
PacoJr67 is offline
Old 08-19-2008, 07:42 PM   #3 (permalink)
j_hoff_05's Avatar
ready tried that
its set on outdoors..
heres a screen shot of the vol
USC MOTOq 9C LIME
Old 08-19-2008, 08:23 PM   #4 (permalink)
papped's Avatar
papped is on a distinguished road
Did you check the profile volume settings for Outdoor?
papped is offline
Old 08-19-2008, 10:46 PM   #5 (permalink)
j_hoff_05's Avatar
how do you do that?
USC MOTOq 9C LIME
Old 08-19-2008, 10:55 PM   #6 (permalink)
sherri's Avatar
sherri is on a distinguished road
Send a message via AIM to sherri
Originally Posted by j_hoff_05 View Post
how do you do that?
On the original Q, it's: start/settings/profiles/(choose the"loud" profile)/menu/edit.
Make sure you have it on "5" for the loudest setting...
sherri is offline
Old 08-19-2008, 10:57 PM   #7 (permalink)
sherri's Avatar
I'm sure that if it is very different on your phone, someone else will be here shortly! ;)
sherri is offline
