Thanks Paco.
But this doesn't make sense. How do you explain my Q9c cannot find even one satellite in google map/wls/sprint nav? ( I did this experiment many times, in my room, a large parking space and downtown). And, How do you explain this:
Originally Posted by mountainwampus Whenever I'm out of cell service, both programs fail to locate me." |
I think there are two possible reasons that my gps doesn't work:
1. my phone is broken.
2. if Q9c can receive satellite signal directly, at least the initial step depends on the sprint tower. data plan is used as a validatoin way.
To prove this, just look around whether there is anyone who can use built-in GPS and meanwhile he/she doesn't have a data plan.
Or, would you mind go to an open space out of sprint coverage? then check your google map (use GPS), or sprint nav (current location). gm may report error, but sprint nav will try to find satellites definately, even without data plan. if they can find satellites, Q9c can receive satellite signal directly. otherwise, I am right.
