Old 03-24-2008, 08:48 AM   #1 (permalink)
usudno is on a distinguished road
Default freezing issues with smart tool kit.
Ever since i installed smart tool kit from BIG-D's apps page my q has gotten slower and now i can't run the app without it freezing first time i hit the tasks softkey. I like the layout and options the toolkit gives but the freezing and slowdown bothers me. Any ideas on whats going on with this thing?
usudno is offline
Old 03-24-2008, 08:52 AM   #2 (permalink)
rainmakerrc's Avatar
Which version did you install? RC08 is the way to go (not the more recent RC09). There are also some things you can do to avoid lockups. I have instructions on my apps page if you want to try them out.
Rob
Apps on my Q9c
rainmakerrc is offline
Old 03-24-2008, 09:56 AM   #3 (permalink)
Now how do i remove the version that i have on my phone now.
usudno is offline
Old 03-24-2008, 10:15 AM   #4 (permalink)
First, go to the task manager and kill the program. Then go to Start-->Settings-->Remove Programs to uninstall it.
Rob
Apps on my Q9c
Old 03-24-2008, 10:32 AM   #5 (permalink)
only thing on the list is sprint navagation.
usudno is offline
Old 03-24-2008, 10:49 AM   #6 (permalink)
Try hooking up to your PC, and in Active Sync on your PC, check the Remove Programs option there. If it's not there, then you may just need to reinstall the version you had before and then uninstall it again. It should be on the Remove Programs list.
Rob
Apps on my Q9c
