Old 06-13-2008, 01:56 PM   #1 (permalink)
krazydawg is on a distinguished road
Default Disable Incoming Call
Is there a 3rd party app or a setting somewhere to just disable incoming calls only but have data still working for the internet. The option for putting your phone in "flight" mode kills all connections.
krazydawg is offline
Old 06-13-2008, 02:52 PM   #2 (permalink)
lincrich is on a distinguished road
Dont have the link right now but search for an app called 'Call Firewall'.
lincrich is offline
Old 06-13-2008, 03:39 PM   #3 (permalink)
or SmartBlock SP: http://www.efficasoft.com/smartblock/index.html
Old 06-16-2008, 01:39 PM   #4 (permalink)
I got it from http://handheld.softpedia.com/get/Sy...ll-39356.shtml The official site appears to be http://www.logic-unlimited.com/callfirewall.php
There is a known issue where your phone will ring once when blocking all calls. The program works as advertised but I was hoping the program would block the call in the way that the other party does not have ring back and it goes straight to voicemail. Example: When your phone is in flight mode or turned off and you receive a call, they will not hear any ring back and the call will go straight to voicemail. With your phone on if you receive a call and you press ignore, the caller will still hear ring back and eventually the call goes to voicemail.
I also tried SmartBlock but it doesn't work as well, however SmartBlock did block the call without the phone ringing on my end. I've terminated the program and it was still blocking calls even after re-checking the option to enable all calls. It also prevents you from making outgoing calls. I did a power reset and uninstalled.
Old 06-26-2008, 09:22 PM   #5 (permalink)
George Knighton's Avatar
George Knighton is on a distinguished road
Send a message via AIM to George Knighton
Do you use this yourself? If you do, would you mind providing a short review?
George Knighton is online now
