Old 06-14-2008, 09:11 PM   #1 (permalink)
ryangab's Avatar
ryangab is on a distinguished road
Need Help Chome Weather current conditons wont stay!!!
Installed this weather...everthing worked fine until I tried to install the colored bar at the top. When I installed that my current conditions went away. I still have the 10 day forecast but I want the current condition to stick. Anybody know how to fix this.
Thanks!
ryangab is online now
Old 06-14-2008, 10:06 PM   #2 (permalink)
rainmakerrc's Avatar
Thanks!
Are you using the Chome Configurator? If so, go into the program and Show the CTestUI panel (i.e., make it visible). Whenever you change homescreens, this panel gets hidden, and you have to make it visible again in your current homescreen.
Rob
Apps on my Q9c
rainmakerrc is offline
Primus (06-16-2008)
