Battery Issues Hi guys,
Last night I was using Opera Mini to check a website and the entire screen froze then turned completely white. To get the Q off, I had to take out the battery. When I tried to power it on, nothing would happen. If I plugged it into the charger the phone would turn on, but only to the battery charging screen. If I took out the battery, left the AC power in, and turned the phone on, it started up like normal. I then put the battery back in and went to bed.
This morning, the phone's alarm woke me up. As soon as I unplugged it, the phone switched off. I made sure the battery was still inserted properly (yes), but, again the phone would not turn on under battery power. Using the trick outlined above, I can get the phone on, but the minute I unplug it, it dies.
Any ideas? |
