Go Back   Motorola Q Forum | Everything Q > Moto Q Software > Mac and Motorola Q
Old 09-18-2007, 07:25 AM   #1 (permalink)
242MotoQUser is on a distinguished road
Default mp3 sync using missing sync
I just purchased missing sync and I am having a hard time sync actual albums. I don't want to sync songs from my mac - rather do actual albums. can some help? is this possible?
242MotoQUser is offline
Old 09-18-2007, 07:28 AM   #2 (permalink)
welcome aboard... you're trying to get the tunes straight from a cd to the Q ? are those regular audio cd's ? not having used Missing Sync don't you need a "converter" to transfer music to a playable format for the Q, like mp3..
Old 09-18-2007, 07:41 AM   #3 (permalink)
Post itunes and mp3s and the Q
I am uisng a mac running OSX using I tunes. Yes, I converted my tunes to MP3 format and synced a play list. What I want to do is sync actual albums not one long list of songs.
Old 09-18-2007, 07:48 AM   #4 (permalink)
(only had 1 coffee yet so bare with me) i am not fully understanding what you wanna do.. with Missing Sync can you access the Q right ? can't you just copy complete directories like us Windows users ?
Old 09-18-2007, 08:02 AM   #5 (permalink)
i think i can access the Q directories using missing sync. So are you saying if I can access the directories I should be able to drag n drop the (albums) to the SD card music directory?
Is my intent clear?
Old 09-18-2007, 08:03 AM   #6 (permalink)
Is my intent clear?
you should be able to copy and paste, not sure about dragging though... if available you can also put the mini sd in a card-reader and "fill" it that way.
Old 09-24-2007, 07:37 PM   #7 (permalink)
beck is on a distinguished road
Are most of you syncing music with Missing synch just copying to SD card or direct to phone? Does Missing Sync actually remove files that are removed from the source iTunes playlist? If I do the initial move of mp3 files directly to the SD card, will a future synch with MS just look for file changes and add or remove?
beck is offline
