Originally Posted by 242MotoQUser Hi - I just downloaded the java files to my Q9m and I downloaded the opera mini to my Q - However, it does not show up in my start file. Can someone help? How do i add it to my start menu? Thanks.. |
It won't, you run Opera Mini from within the Java Client (Emulator.exe, should be in the Bin folder). Once you install the Java Client, run the Emulator, click on install and browse to where Opera Mini is stored. After the installation (you might need to reboot the phone), to run Opera Mini, you run the IBM Emulator (create shortcut) which will come up with a list of Apps installed, select Opera Mini and off you go.
After all this hustle, to be honest, I'm not very impress by Mini, I'm not a Microsoft fan, but I thinks IE is easier to use and just as fast. The good news is that once you have the Java Client installed, you can download tons of apps and games written in Java. I hope this help you.
