Originally Posted by casemods Well I figured it out, you have to set the sound profile to headset, then it will automatically play through the headset when you attach it. But not for everything, unfortunately. |
Most Windows Mobile devices route all audio through the headset jack if you connect a wired headset.
If you're using a Bluetooth headset, check the
Advanced settings in Bluetooth Manager and make sure
Use Hands-free for standard audio is checked. That should route all audio to a Bluetooth headset.
Steve
