Go Back   Motorola Q Forum | Everything Q > Other > General Discussion
Old 04-01-2008, 03:36 AM   #1 (permalink)
maheshmaestro is on a distinguished road
Default push e-mail help
I configured my office email as push and its working fine.But its always keeping only 3 days worth mail and not the old mails. Is there a way i can configure the number of days i can keep the mails.
Appreciate your help.
Thanks,
-Mahesh.
maheshmaestro is offline
Old 04-01-2008, 06:06 AM   #2 (permalink)
search... search. discussed on almost a daily basis...
potQ.
Old 04-01-2008, 06:16 AM   #3 (permalink)
I understand your comment... I honestly did search in the threads and in google probably am not good at the keywords i give for searching. Am not getting what i want exactly although i got lot of other answers.
potQ.
Old 04-01-2008, 07:46 AM   #4 (permalink)
rainmakerrc's Avatar
Which Q do you have and on which provider?
Rob
Apps on my Q9c
rainmakerrc is offline
Old 04-01-2008, 08:17 AM   #5 (permalink)
am using moto q 9h and provider is vodafone in india.
Old 04-01-2008, 08:22 AM   #6 (permalink)
Check your email settings. There should be setting for how many days worth of messages your Q syncs (today, last 3 days, last 7 days, etc.). You should be able to change that on your Q. If there is another program that handles the pushing for you, then you may need to check the settings there.
Rob
Apps on my Q9c
Old 04-01-2008, 08:32 AM   #7 (permalink)
My gmail has that option which is imap. But my office mail box which is configured via outlook and push (i guess) does not have the option of setting the number of days mails should be kept.
Old 04-01-2008, 08:33 AM   #8 (permalink)
Did you set up your office email, or did your IT department?
Rob
Apps on my Q9c
Old 04-01-2008, 08:44 AM   #9 (permalink)
I did. i get mails it works fine but i can see only last 3 days mail.
Old 04-01-2008, 08:47 AM   #10 (permalink)
Can you access any settings for your work email? How exactly do you have it set up?
Rob
Apps on my Q9c
