Haven't seen any major problems. I love the Parrot CK so I went down to old work and paired it to check it out. Are you holding a constant connection to the CK? This may be causing some issues.
Are you also transferring you Contacts in it and using its full potential? This is for myself since I hadn't tried it
Thanks.
-A
