Old 01-18-2007, 08:53 PM   #1 (permalink)
Question power usage BT ?
another quicky.. if i leave Bluetooth "ON" but don't use a device all the time, does that use more power/battery ?
currently i'm resting w/ the idea that the Bluetooth w/ the Vaio isn't working so i'll use USB.. i want Bluetooth on because i just bought a ear-piece (
Plantronics Voyager 510)
Old 01-18-2007, 10:05 PM   #2 (permalink)
smeg36's Avatar
smeg36 is on a distinguished road
It does use more battery, but not very much. Some people will say to turn BT off when you aren't using it to save battery, but it really isn't even worth it. I've personally done battery tests with a few different devices, and I typically got about 15 minutes of power less with BT on than with it off.
Device: Motorola Q (Sprint)
Accessories: Burgundy Jabra JX10, 2GB Sandisk miniSD, Leadtek 9537 BT GPS
Editor: www.mobilegadgetnews.com
smeg36 is offline
Old 01-19-2007, 11:57 AM   #3 (permalink)
Smile
thanks, 15 minutes is not really worth turning it off and on every time i want to use it.
Old 01-19-2007, 12:42 PM   #4 (permalink)
VTDr0p0ut's Avatar
The big power killers are Receiving incoming beams, POP3 polling, and frequent syncing w/ WirelessSync/Exchange servers
VTDr0p0ut is offline
Old 01-22-2007, 08:22 AM   #5 (permalink)
Question
none of those mentioned i freuqently use so i 'm good... another battery question, i don't want my battery to run out while at work, is it bad practice to charge the Q every night ?
Old 01-22-2007, 10:25 AM   #6 (permalink)
smeg36's Avatar
No, charge away. With older batteries it may have been folly, but with the newer Li-Ion batteries it doesn't make a difference. I put mine on the charger whenever I'm at home.
smeg36 is offline
