Home Motorola Q Store Moto Q Software News Motorola Q Reviews Moto Q Forums Q Social Contact Us Everything Q RSS feed
Old 02-19-2007, 09:27 AM   #1 (permalink)
Need Help Plantronics Voyager 510
been using this BT headset for about 4-5 weeks without issues, now all of a sudden last week it keeps losing it's connection to the Q for (to me) unknown reason, could it possibly be CandleLight ? that's the only thing i installed last week... when the connection is lost i have to go into the BT Manager to establish it again, also it used to connect immediately when i turned it on, since the issues started i have to manually find it.
any one any idea ?
thanks in advance..
Old 02-19-2007, 07:12 PM   #2 (permalink)
Smile *fixed*
well, here is what i tried: after i wrote the previous msg i turned off CandleLight and not one time today did the headset disconnect... so it looks like that (CandleLight) was giving me the issue.
seeing no responses here so i am going to assume no one else has/have a similar issue.
it's a shame because i really wanted to use CandleLight.
Old 02-22-2007, 09:51 PM   #3 (permalink)
shu_mai is on a distinguished road
Default Thanks for tip!
Having my plantronics 510 cut out at random times during the day has been so frustrating... so I was so glad to find this post. Thanks for the tip - I've also removed candlelight and will see if this works.
shu_mai is offline
Old 02-22-2007, 09:58 PM   #4 (permalink)
i was pleased it solved my issue, less happy w/ the fact i can't use CandleLight but a working headset has a bit more priority (although what's a working headset if the battery is drained :}
keep is posted.
Old 05-07-2007, 07:43 AM   #5 (permalink)
mnmorena is on a distinguished road
Need Help Still not working...
I don't have candlelight, but my plantronics disconnects after about 15 seconds from my Q. Can anyone please assist me?
I have gone into the BT properties and tried it with the "connections authorized" box both checked and unchecked. Neither way helps keep it connected.
Thanks in advance for your help!
mnmorena is offline
Old 05-07-2007, 12:21 PM   #6 (permalink)
jim9112 is on a distinguished road
is it a 510, i had troubles with my 540e the q doesnt seem to like every model from every brand
Verizon Q
jim9112 is offline
Old 05-07-2007, 12:24 PM   #7 (permalink)
Yes, it is the 510. Some people seem to be doing just fine with this headset, while others are not.
The Q finds it and everything...it just disconnects it after so many seconds for some reason.
mnmorena is offline
Old 05-11-2007, 12:29 PM   #8 (permalink)
bobbyC303 is on a distinguished road
Default Can't Initiate with the 510
I haven't been having a disconnect issue but I can't initiate or answer calls with my voyager 510 headset. Anyone else have this problem?
thanks
bobbyC303 is offline
Old 06-18-2007, 03:10 PM   #9 (permalink)
applejosh is on a distinguished road
I know this is an old thread, but I thoght I'd share my experience with this combo.
The connection will drop out on occasion, usually when in the presence of another bluetooth device. Kind of weird. I usually have to re-connect, but a couple of times, it re-connected automatically (usually after 30 seconds or so).
I couldn't answer using the button on the side of the Plantronics, but disabling QCaps might have fixed this. (I have only received one call since disabling QCaps, and I was able to utilize the call button on the 510.)
Just thought I'd throw those out there for collaboration purposes.
applejosh is offline
