Old 06-20-2008, 06:18 PM   #11 (permalink)
yameen1 is on a distinguished road
which are you going to go with?
not sure - is there a difference in the features/capability in the 520 v. 610, or is it just a comfort issue? The 610 seems a lot cheaper, and if it does the same thing and its not uncomfortable for me, then the 610 might be the way to go.
yameen1 is offline
Old 06-20-2008, 07:51 PM   #12 (permalink)
compare them & go from there.. from experience I say the 510 is superior.
potQ9c
Old 06-21-2008, 10:00 AM   #13 (permalink)
cliffr39 is on a distinguished road
I got a 520 from eBay new still in the plastic for $40 shipped. When it arrived I paired it up with my one regular phone (enV2). It paired up no problem but was horrible - had static when I was holding the phone on the opposite side of my body as the 520 was (in right ear and left hand). When I paired it up with my Q9m it works just fine and I can actually walk around the room with no static. Not sure what the difference was but it's a decent headset with the Q's
cliffr39 is offline
Old 06-21-2008, 11:03 AM   #14 (permalink)
I meant to say the 520 !!
potQ9c
Old 06-25-2008, 09:14 AM   #15 (permalink)
pgreenbe305 is on a distinguished road
Default Hey...
potQ9c
Don't diss the 510- it's a great headset. I use it daily, and love the hell out of it. How much more is a 520? I didn't even see it, and my friend works at Office Depot, so I had gotten the 510 for $40, new, in store, which I thought was ok, but I don't know.
I don't think you can go wrong with any of the $40+ Plantronics models.
pgreenbe305 is offline
Old 06-25-2008, 11:25 AM   #16 (permalink)
it was not my intention to dis.... my 510 served me well for about a year & it's (still) a great headset, i just moved on for various reasons..
Old 06-25-2008, 07:01 PM   #17 (permalink)
Default Correct me if I am wrong...
The 510 & 520 are completely different, right? Style, mic, fitting, etc- no?
Their naming/ numbering system is goofy.
Old 06-25-2008, 07:15 PM   #18 (permalink)
I would think the technology is similar, fitting and style is different indeed.
potQ9c
