Originally Posted by PNut It isn't you. The headset just doesn't work well with the Q. There are lots of known BT issues with the Q and headsets. |
Not truei have H700 it works perfectly the problem is is your H700 revision a or B if it is a then you have problem CDMA with rev B works perfectly the other thing is is it real ot fake if it fakes then forget it....
Look at the back do you see a bluetooth logo and motorola imprint if so you are ok if not then you going to have a lot of problems''I bought one from ebay fake never workied static and echo.. I purcahse from compusa $$40 after rebate and original works 100% perfectly even when i am 25 feet away i am listening to songs on bluetooth and even talking to my friends 25 feet away very little static.....
