Originally Posted by freaksite has anyone had problems pairing their s9 with their Q? i bought some off ebay and its being a pain to sync up properly. it'll work but the music is all choppy and cuts in and out. i've callled bell and motorola about it and they just jerked me around. i took it to the place where i bought my Q and we tried the S9's on a different phone and they worked fine.... and my phone works with my other bluetooth devices. if anyone has any advice that would be great. |
Might be a couple of different reasons,
If you are outside and your q is in your pocket it may be bad reception/interference. I get flawless reception when I put my q9c on a beltclip (even if my jacket is covering it)
My S9 cuts in and out when the battery is low. Keep it fully charged.
I sometimes need to re-pair the S9 to my phone b.c. once in a great while it will get a bad connection. When reconnecting pair it up as a stereo headset first, then it will ask if you want to connect it as a hands free device as well. This always works for me.
Hope that helps.
