Originally Posted by zdemiral I was wondering if someone might be able to provide step-by-step instructions to pair my GPS receiver with my Q (Sprint). I've tried everything including the Went through the BT Manager and went to Settings. - Selected Menu (right soft key).
- Selected Paired devices and then went to Menu.GPSCOM.exe but I still get a message, "Services not found" when I try to pair the GPS receiver with the Q. I have a Navibe GB735. I followed the steps below. What am I doing wrong? What am I missing? I managed to get it to connect once a few days ago, lost the connection and have never been able to retreive it.
- Hit Add - Searched and found BT GPS V10.
- Selected it and entered the passkey (0000). Hit Done.
- Selected it and went to device Properties and Nicknamed the device Navibe Device.
- Hit Done and went to the Menu again, and Serial Ports; the BT GPS V10 was the default device for outbound connections (Outbound COM Port: COM1:; I did NOT check the box for "Select new device for the next outgoing serial connection".
- Turned the phone off and then on.
- NOTE: The device never paired up.
- Then went to BT Manager again and selected Hands-Free.
- Went to Menu and selected Add.
- Hit Search, then Menu again, Selected Show All Devices, Selected Navibe Device once it showed up on the list.
- The phone checked for services and then gave me the following message, " Services Not Found."
- I then ran the GPSCOM.EXE file and made sure it was enabled. I tried COM6 as well as COM1.
- Turned phone off and then on again ...
And still NOTHING. Yes, the BT is on.
Any suggestions?? I'm at such a loss.
Thank you!
~ z |
What software are you using? googlemaps, WLS, or something else?
