Originally Posted by SgtTurtle I ordered one of these and received it today. I am having trouble getting it to work.
To pair it, I had to go to Bluetooth Manager -> Settings -> Menu -> Paired Devices -> Add
I then entered the passkey, 1234, and it now shows in my Paired Devices with a question mark on the icon, but does not show in my Connections.
I have tried Windows Live Search (WLS) with every com port and could not get it to work. I also tried Maps4PDA because it can search the com ports, but its search came up with nothing.
Has anyone had any luck getting this to work, and if so, please post the necessary steps.
Thanks in advance. |
I also hav the Freedom Key Chain GPS, and for days i had the same problem, but after reading threw a ton of fourms and threads i found a fix, you need to d/l this thing called " gpscom.exe" Pair up your Q with the gps, after that run the .exe on your Q and change the "Selected com port" to com1, then restart your q. After i did that the gps works with google maps, windows live, and map4pda, thoes are the only apps i have used so far but no need to test more, hope that helpes...
