Originally Posted by MrClean I purchased a BT-GPS receiver for my Q and also got an 'active external antenna'. The antenna is magnetic obviously, I was wondering if it could be placed under the hood (in the engine compartment) and still work properly. I wouldn't mind putting it on the roof of my truck but I'd rather have it in a place that's not out in the open. If it's under the hood it'll make it easier for me to route the cable to the interior of the vehicle.
Thanks in advance! |
I used to work at Car Toys. I would actually recommend NOT doing that. The antenna needs a clear signal of the sky without anything blocking the view for it to work properly and to get the reception from all the available satellites.
There are ways to install it on the exterior of the vehicle, most likely within 2-4 inches of the corner where the windshield and the driver door meets. Then you face the antenna towards the door where the weatherstripping is. This will only leave about 1/2-1 inch of antenna exposed. The cable can then be routed through the weatherstripping, down the doorjam, across the dash where the window meets to hide the cable. You can then either route it through the dash or have it sittings across on the center. Most installs done where through the dash, down under and would route into the center console depending on the length of cable.
-A
