Old 02-04-2008, 11:41 AM   #1 (permalink)
Scruffy is on a distinguished road
Default Connection Issues & Notification Sound
I am using the H700 and have 2 issues. The first is that the headset keeps connecting and then disconnecting on its own. My Q and the H700 are sitting side by side.
Second problem comes with the first. Every time it connects or disconnects I get a notification tone. I don't mind getting the tone so I know that I am having issues, but could use some volume control. I have searched and searched, but can't come up with the proper spot.
Scruffy is offline
Old 02-04-2008, 11:46 AM   #2 (permalink)
mike250rs's Avatar
assuming you have good batteries in both devices...
do you have another BT device you can pair with?
mike250rs is offline
Old 02-04-2008, 11:52 AM   #3 (permalink)
I do have another BT (Pantronics) and do not have the same issue. Battery is fully charged in both the phone and BT.
Scruffy is offline
Old 02-04-2008, 11:59 AM   #4 (permalink)
mike250rs's Avatar
That kinda points to the H700 as being the culprit.
Old 02-04-2008, 12:37 PM   #5 (permalink)
I was thinking the same thing. This is the second H700. They replaced the first one and it didn't take care of the problem. Made me think it was the Q until I did a warranty replacement on the Q. Still having the same problem.
Scruffy is offline
Old 02-04-2008, 12:48 PM   #6 (permalink)
mike250rs's Avatar
no telling how many were returned and just put back on the shelf
Old 02-04-2008, 02:12 PM   #7 (permalink)
Good point. I brought my Plantronics in from the truck to test it in the same environment as the H700. Haven't had a drop yet. I may just give up and return the H700 for a different model.
I also figured out how to lower the volume on the notification that I was connecting and disconnecting. At least I can fix that issue.
Scruffy is offline
Old 02-04-2008, 02:32 PM   #8 (permalink)
ryant35's Avatar
ryant35 is on a distinguished road
My old Jabra had set used to dissconnect and reconnect all them time. I smashed it and bought an H700C and it works great. I've never had a disconnection problem. I have had a couple of times I turned on the BT during a call and it didn't connect, I turned it off and back on and it worked fine.
IMO you can't beat the headsets with a switch. It saves a ton of batteries on both devices.
ryant35 is offline
Old 02-04-2008, 02:45 PM   #9 (permalink)
mike250rs's Avatar
the woman never had a problem with the one time she used hers. Last seen swirling around the bottomless pit she calls a purse.
I thinks you just got some bum devices
The Following User Says Thank You to mike250rs For This Useful Post:
Scruffy (02-05-2008)
Old 02-05-2008, 06:12 PM   #10 (permalink)
I have to agree. Tomorrow's chores include exchanging for a different model. One last question: every hear of interference causing problems? I have a co-worker using an H700 (same as mine) that sits about 10 feet away. Problematic?
Scruffy is offline
