Originally Posted by inf3st Troutseth,
So WLS and Google Maps don't provide voice? If that is the case do these free programs update their selves and show you were you are? |
I do not use the new Google Maps, but WLS will give an audible beep when a turn is upcoming. They do update based on where you are so the map and directions follow you. What they do not do, is give you voice 'turn right" so you have to glance at the unit when it beeps. They do not re-route when you go off path. I found out that this is a license issue with the data providors not a technical issue and that WLS may add this in the future (no promises).
Now I have to be fair to you, the first WLS release (non Beta) just came out so I have not tested all of this yet.
