Originally Posted by hilgerone I admit, I was very impressed with the noise canceling. What type of environment were you using for background noise just out of curiosity? Any others you have tried that you felt were inferior to the Jawbone?
Thanks for your help. I'm digging the Jawbone back out now. Matt |
I need the noise cancellation primarily to block out road noise at highway speeds and in loud public environments like airports, restaurants, etc.
I have tested quite a few bluetooth headsets by leaving myself voicemail from different environments, and I have found the Jawbone to be the most effective in blocking or significantly reducing background noise. Many headsets either seem to accentuate background noise or exhibit distortion of the outgoing sound in noisy areas.
I liked the Voyager 520 in quiet and moderately noisy environments and it had fewer connection quirks with the Motorola Q, but I feel that the Jawbone does better as the noise level increases. Obviously, my experience differs from others in this regard.
With your high noise environment, I do think the Jawbone will be hard to beat. Let me know if setting the headset profile to vibrate on the Q solves your connection problems like it did for me.
In the meantime, I'll continue to be on the lookout for the holy grail of headsets!
Regards,
Dave
